  • 25 Vote(s) - 2.84 Average
Faac 455d Control Panel with XF868 Receiver
(29-10-2021, 02:20 PM)Dec Wrote: Hi I am installing an xf868 receiver to my 455d control panel but I am wondering is this quick connect as cables come loose when I connect up to power supply manually when pushed in. The receiver is 3 connectors but panel at quick connect is 5, ant help here would be great.
Hi Dec,
Power will be wired into the receiver. You will then need to wire from the relay outputs to the push button/open input on the 455d panel. When the receiver is triggered, it will trigger the input, opening the gates.
-Jamie
RE: Faac 455d Control Panel with XF868 Receiver - by JamieF - 04-01-2022, 09:42 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,651 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,321 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,050 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,986 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,763 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,387 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,375 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,116 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,767 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,525 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
