  • 254 Vote(s) - 3.11 Average
BFT controlled gates open but don't close
(16-09-2016, 02:33 PM)MikeJep Wrote: Hi all - we've a couple of swing arm gates controlled by a BFT Aries.  The system is about 20 years old but has been reliable till now.
Recently the gates opened then wouldn't shut.  We could unlock the arms and manually shut them ok.  Once locked again they would open on demand perfectly but, once open fully, wouldn't close again.  There is plenty of ticking going on from the relays as the shut cycle is supposed to happen and there is even power to the motors (haven't tested polarity) - but no movement.  The gates move freely once unlocked
Any ideas much appreciated.
Can you see any fault codes on the panel? If not, I would recommend running the motors on new cabling directly into the board, as well as your safety devices and photocells.
Reset the panel and see if this works, if so, it is more than likely a cabling issue. If not, the board is probably faulty due to the age. I would also say if you have x2 motors you can learn these in single mode, so if it is a motor fault you will be able to determine this.
-Jamie
BFT controlled gates open but don't close - by MikeJep - 16-09-2016, 02:33 PM
RE: BFT controlled gates open but don't close - by JamieF - 04-01-2022, 09:58 AM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,931 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,945 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,341 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,540 04-11-2024, 05:59 PM
Last Post: Sootylfc
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,644 17-07-2024, 02:24 PM
  Two BFT pairs of electric gates (one remote) Harry44 1 4,249 04-06-2024, 01:30 PM
  Gate wont close issue MR_ROBOT 3 16,853 11-04-2024, 08:08 AM
  Ecosol/Kustos doesn't open and close fully? supremee 3 6,984 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 3,778 19-01-2024, 09:54 AM
  BFT LUX2B Intermittent failure to open brookkr 4 13,373 07-09-2023, 08:32 AM
