  • 329 Vote(s) - 2.94 Average
cb24 photocells
I have a CB24 board with photocells. They are set to operate on close only and have been working fine for a couple of years. Now, instead of a consistent red light on the cells, there is an intermittent flash - time between flashes can be between 2 seconds and 40 seconds. Occasionally they will stay on long enough for the timer to run out and will then go off.
This of course means i cannot close the gates. Even removing the photocells from the circuit and shorting the connectors won't allow me to close (can the learning process of the photocells be 'unlearnt'?)
I have checked the batteries (12.5v and 12.7v respectively) and cleaned out the inside of the cells (and evicted spider!) with no luck.
The only oddity i can see is perhaps (and this might be my imagination) that one light is brighter than the other - and the duller one is at the end of the longest cable run.But as i said it has been fine for 2 years - and has worked ok twice today.
Any advice would be appreciated
cb24 photocells - by devonaloan - 26-11-2011, 05:59 PM
RE: cb24 photocells - by Mark - 28-11-2011, 05:57 PM
  Adding Extra Photocells To CB22 Onoff 0 7,458 06-08-2020, 01:01 AM
Last Post: Onoff
  chamberlain photocells wlehane 3 33,025 02-09-2019, 10:00 AM
Exclamation lift master SCS300 - photocells Willow 1 13,062 14-07-2016, 09:16 PM
Last Post: Willow
Exclamation lift master SCS300 - photocells Willow 0 9,688 13-07-2016, 11:19 AM
Last Post: Willow
  CB24 delay to close random fault stuartdsutton 0 10,065 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,348 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 15,299 20-08-2012, 09:40 AM
Last Post: Mark
  Wiring relay to CB24 magga 4 25,252 01-08-2012, 06:35 PM
Last Post: magga
  Liftmaster CB24 key switch Mel1962 2 18,742 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB24 Problems andydday 3 21,965 06-02-2011, 11:39 AM
Last Post: Guest
