  • 30 Vote(s) - 3.57 Average
FAAC sensors and Beninca R16E motor
Many thanks Sam. I now want to change my FAAC sensors to Beninca Pupilla sensors. Connecting to Beninca R1.6E motor as before. So it's Beninca to Beninca. My question is how to wire up. The FAAC RX sensor has four terminals but the Beninca RX sensor has five. The Beninca diagram is confusing. Two terminals on the RX sensor are labelled 24V AC (+) and (-) 24V DC. They leads go to the transmitter sensor (RX). where there are two terminals + and -. So far so good- I hope! (But why labelled AC and DC?) The other three Beninca terminals are obscurely labelled. C is Common. NO is 'Normally Open'. NC is 'Normally Closed'. The NC is described as 'with powered and aligned photocells' and it shows a switch between the NC and ND terminals. What does all that mean for the wiring of the last two leads used by the FAAC sensor? There are other spare leads that were not connected to the FAAC RX sensor. Any clues appreciated.
RE: FAAC sensors and Beninca R16E motor - by SamA - 12-07-2022, 11:44 AM
RE: FAAC sensors and Beninca R16E motor - by Beachcomber - 14-07-2022, 04:10 PM
RE: FAAC sensors and Beninca R16E motor - by SamA - 18-07-2022, 10:44 AM
RE: FAAC sensors and Beninca R16E motor - by SamA - 20-07-2022, 09:50 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,688 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,333 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,064 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,003 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,773 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,398 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,405 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,129 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,780 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
