  • 23 Vote(s) - 3.43 Average
Robus 600 not closing fully
#11
(20-07-2022, 09:47 AM)SamA Wrote:
(19-07-2022, 08:36 AM)All Well Wrote:
(18-07-2022, 10:38 AM)SamA Wrote:
(18-07-2022, 09:05 AM)All Well Wrote:
(18-07-2022, 08:59 AM)SamA Wrote: Hi,
Thanks. Another thing: Can minor adjustment be made to the closed position. The gate stops about an inch or so short which prevents proper locking.
Of course.
Finally found the solution: At the rear end of the close contact lever there are two screws which can be loosened and the lever moved backward or forward to make the gate stop later or earlier respectively. So it is a mechanical adjustment solution!
Thanks a lot. Regards
Robus 600 not closing fully - by All Well - 10-07-2022, 09:31 AM
RE: Robus 600 not closing fully - by JoeF - 12-07-2022, 11:35 AM
RE: Robus 600 not closing fully - by All Well - 14-07-2022, 11:10 AM
RE: Robus 600 not closing fully - by All Well - 14-07-2022, 11:13 AM
RE: Robus 600 not closing fully - by SamA - 18-07-2022, 08:59 AM
RE: Robus 600 not closing fully - by All Well - 18-07-2022, 09:05 AM
RE: Robus 600 not closing fully - by SamA - 18-07-2022, 10:38 AM
RE: Robus 600 not closing fully - by All Well - 19-07-2022, 08:36 AM
RE: Robus 600 not closing fully - by SamA - 20-07-2022, 09:47 AM
RE: Robus 600 not closing fully - by All Well - 25-07-2022, 09:38 AM
RE: Robus 600 not closing fully - by JoeF - 18-07-2022, 09:00 AM
RE: Robus 600 not closing fully - by benbrooks - 03-08-2022, 02:42 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,033 03-12-2025, 04:18 PM
Last Post: StefanP
  Beninca BOB30ME - Not closing all the way OMH 0 298 26-11-2025, 10:31 AM
Last Post: OMH
  Gate not closing thronetm 0 4,168 16-11-2024, 09:25 PM
  Robus Not Operating AlanWhite 3 16,786 11-09-2024, 05:00 AM
Last Post: Lee Zhang
  Program a 3rd party remote to Nice Robus N600 P100D 4 8,727 13-05-2024, 03:36 PM
  Nice Gates not closing StuL 1 7,864 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,343 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  LIFE AC4 Closing Issues dilbertdog 0 2,843 29-07-2023, 02:59 PM
Last Post: dilbertdog
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 11,744 02-12-2022, 02:51 PM
  Aria 400 - gates keep opening and closing objohnuk 1 7,940 13-04-2022, 11:32 AM
