  • 27 Vote(s) - 3.33 Average
Came FROG-A + ZA3 controller > gates wont close safety beam
Hello
we have 2 x FROG-A 230V underground motors and ZA3 control panel on a double leaf gate which have been working fine for about 6 years.
Gates are now stuck open and I noticed that when a button on the fob is pressed one gate moves about an inch to try to close and then opens and stays open.
I opened the control panel and the red led and green flashing led are both lit when powered.
When I press the fob I can hear a click (relay?)  and then the green led goes out but comes back on after about 12 seconds.
(a) could it be due to the age of the capacitors  > should I just replace them
(b) would a fault with the safety beam or a broken wire cause this     I ask as I would usually hear a click when walking through the beam but it doesnt appear to be making the noise now   >  can i turn off the safety beam using the dip switches or override to test
I would guess that it is unlikely to be an issue with the beam transmitter / receiver but how could i check this ?
thanks in advance for any suggestions
Came FROG-A + ZA3 controller > gates wont close safety beam - by endam - 26-07-2022, 10:41 PM
  CAME ZF4 Controller Issue mduffy89 1 1,517 11-11-2025, 03:14 PM
  Came Frog nuphor 1 4,788 10-12-2024, 09:31 PM
Last Post: nuphor
  Gates not closing Regor23 5 7,344 03-09-2024, 12:51 PM
  CAME Frog AE-p24 kit Push Button Stuartl 2 7,245 20-10-2023, 08:57 PM
Last Post: Stuartl
  Frog A24E motor stopping SW1806 7 16,142 24-03-2023, 02:58 PM
  Gates out of sync frankjboyd 5 24,430 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 14,792 14-11-2022, 11:59 AM
  Came FROG A noisy fezster 1 7,697 30-09-2022, 03:16 PM
  My Came ZM3E gates won’t open golfnut75 1 10,774 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 14,936 24-06-2022, 08:58 AM
