  • 12 Vote(s) - 2.5 Average
LUX G BT 2B not closing properly since manual override
(21-07-2022, 11:09 PM)swinnie Wrote: I have 2 x LUX G BT 2B arms which had to be manually overridden whilst I was away due to a power failure.
In doing so they lost some fluid out of the override screw.  The gate opens correctly, but when closing it closes fully and then opens on one side by 300mm.  I'm guessing we need to top it up with oil?  Do we fill up via the override screw or elsewhere?  The diagram in the manual is not clear!
Or is it not the oil that is causing the issue?
thanks for the message,
i do not believe you can re add hydraulic fluid to these motors and BFT usually can carry this out at a cost.
RE: LUX G BT 2B not closing properly since manual override - by JoeF - 03-08-2022, 01:44 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,479 14-06-2024, 12:12 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,219 04-01-2024, 10:21 AM
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 7,802 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,451 09-01-2023, 10:29 AM
  PHOBOS N Manual Overide Problem Dazrob 3 7,238 06-12-2022, 07:29 PM
Last Post: Dazrob
  Gates not fully closing stefen1978@hotmail.co.uk 2 7,362 10-10-2022, 10:07 AM
  Slider closing then reopens 8" MWJONES 4 25,895 14-03-2022, 12:04 PM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 5,954 07-03-2022, 11:24 AM
  Phobos reversing after closing Sim75 0 3,952 21-05-2021, 07:04 AM
Last Post: Sim75
  Gates not closing (BFT Thalia btl2 and Bft Desme) Joel23M 2 11,883 17-01-2021, 01:25 PM
Last Post: Joel23M
