  • 33 Vote(s) - 3.15 Average
My Came ZM3E gates won’t open
(04-08-2022, 10:16 AM)golfnut75 Wrote: I II cI came  back to my gates last week and they suddenly just would not reopen.
I’ve opened the came box up and all looks fine. No fault codes and the board looks in perfect condition .  I changed the 4 fuses and that did not help. When I press my fob it asks for them to open as you hear the clicking noise but then nothing responds. I changed the 2 16uf capacitors thinking they had gone with the heat but that has not fixed it.
My only thought is that the underground motors have failed . But for both to fail at exactly the same time does make me think that is not right either. I opened the underground motors and they all look fine . I put WD40 on each but still no luck.
Having exhausted all my limited options I think I need the experts please. Aany advice would be graeatly received. . Thanks
Good Morning,
At this point it is trial and error to pinpoint the issue, i would recommend running the gate in single mode (single motor). Take out motor 2, learn the limits and see if it runs. Then do the same with motor 2 in the motor 1 output. If one motor moves in the motor 1 output you know the other motor is the issue. If no motors move you know its the control board output failure.
Kindest Regards,
My Came ZM3E gates won’t open - by golfnut75 - 04-08-2022, 10:16 AM
RE: My Came ZM3E gates won’t open - by SamA - 12-08-2022, 08:40 AM
  Gates not closing Regor23 5 7,336 03-09-2024, 12:51 PM
Last Post: Ivorwindybottom
  ZM3E underground loop problem GhostUK 4 12,602 20-03-2024, 10:46 AM
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 17,197 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 24,411 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 14,777 14-11-2022, 11:59 AM
  ZA3 Came gates not opening with RF device chooper 5 14,925 24-06-2022, 08:58 AM
  Came FROG - one leaf occasionally does not open fezster 3 12,984 03-08-2021, 10:07 AM
  Came Gates - power cut issues Paddy_SP 2 12,823 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  CAME ZM3E Mike2006 0 13,495 28-09-2020, 07:48 PM
Last Post: Mike2006
  Came Double Swing Gates opens by itself for some centimeters risp73 0 10,228 19-06-2020, 06:19 PM
Last Post: risp73
