  • 24 Vote(s) - 2.75 Average
BFT Thalia ‘Hold Open’
(02-10-2022, 12:52 PM)hehasmoments Wrote: Hi guys,
Got a BFT Thalia L which is all configured up and working fine, but was trying to find a way of configuring them to stay open on the 2nd button press.
As far as I can tell all of the opening modes (Open, Open Timer, Start I, Start E) all open, wait for the TCA timer and then close again.
None of the step by step movement options seem to have a step which makes them stay open either. (E.g. press open when already open)
I’ve wired the 2nd channel output relay to the IC2 input, so just want to find some logic which works for opening on a button press and then staying open until the next press.
I also want to keep the normal button as open -> timer -> close.
Does anyone know if that’s possible?
Thanks!
By the looks of the manual, IC0 and IC1 can be configured to step by step (4 step). The second command is a stop command if the Step by step logic is set to 0 (4 step).
Hope this helps.
BFT Thalia ‘Hold Open’ - by hehasmoments - 02-10-2022, 12:52 PM
RE: BFT Thalia ‘Hold Open’ - by SamA - 06-10-2022, 10:49 AM
RE: BFT Thalia ‘Hold Open’ - by Dr_mariano - 24-01-2023, 05:49 PM
RE: BFT Thalia ‘Hold Open’ - by JoeF - 03-02-2023, 12:07 PM
RE: BFT Thalia ‘Hold Open’ - by Caesium - 18-08-2023, 03:30 PM
RE: BFT Thalia ‘Hold Open’ - by JoeF - 24-08-2023, 01:38 PM
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,967 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,357 03-02-2025, 11:29 AM
Last Post: Sootylfc
  BFT Thalia no power on accessory ports (50, 51) tjomk 2 4,483 22-10-2024, 02:54 PM
Last Post: Bigmac3112
  Ecosol/Kustos doesn't open and close fully? supremee 3 7,006 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 3,788 19-01-2024, 09:54 AM
  BFT LUX2B Intermittent failure to open brookkr 4 13,397 07-09-2023, 08:32 AM
  Set remote to “only open” gate mark123499 4 10,028 30-05-2023, 01:57 PM
Last Post: mark123499
  Thalia P - Wireless control board module mathewnorris22 1 6,528 02-03-2023, 03:17 PM
