  • 22 Vote(s) - 3.59 Average
BFT Rigel 6 - Buttons suddenly stop working
(10-10-2022, 09:25 AM)RobE Wrote: Morning!
The buttons on my Rigel6 have suddenly stopped working. I've checked the connections for power (50/51) and I can see wires plugged into 60+61 and 60+64. I'm assuming 64 are the two gate buttons and 61 are the ground loops. When I open the board the letters PED are showing on the LCD display.
My question is - if there is an issue with a particular pin on the board (61 for example) can I relocate the connections in 61 to 64 with no ill effects or will this affect the programming on the board? I assume 64 normally issues the PED command which the board is configured for opening a single gate and attaching to 61 will open both gates.
Cheers,
Rob
thanks for the message,
if you are using other pins on the board there is not an issue doing this however, the logic on the board will need to be reconfigured via the logic settings.
Many Thanks
RE: BFT Rigel 6 - Buttons suddenly stop working - by JoeF - 10-10-2022, 10:03 AM
  Bft photocell not working Tomtom 1 763 11-11-2025, 03:29 PM
  BFT Gate Motor - Not working elyoussef.ali 1 6,207 11-09-2025, 10:15 AM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,960 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,069 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,356 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 4,745 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,022 30-10-2024, 12:54 PM
Last Post: Vaf888
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,098 15-10-2024, 10:37 AM
  Gate radio receiver not working Zhymke 0 2,963 23-05-2024, 06:35 PM
Last Post: Zhymke
  BFT Rigel 5 issue Adamit 0 2,736 17-05-2024, 10:28 AM
Last Post: Adamit
