  • 28 Vote(s) - 3.18 Average
Came Gates Error code E14
Thank you for your enquiry,
Have you tried to re-establish a connection between the motors and the control board to check whether it could be loose terminations, further more you could go to the control board and swap over the motors control board side and see if the error stays with the motor or changes motor, if it changes motor then this would indicate a panel fault.
I would also try resetting the limits too if possible.
Came Gates Error code E14 - by janker - 19-10-2022, 12:48 PM
RE: Came Gates Error code E14 - by benbrooks - 21-10-2022, 11:50 AM
RE: Came Gates Error code E14 - by janker - 22-10-2022, 04:16 PM
RE: Came Gates Error code E14 - by benbrooks - 14-11-2022, 11:59 AM
  E8 error Code won't go away Singhsan 2 10,645 22-04-2025, 08:27 PM
Last Post: Mibbo
  Gates not closing Regor23 5 7,338 03-09-2024, 12:51 PM
Question Encoder Error!2 (ZM3EZ with ATS-P5) jagnew 0 6,266 29-03-2024, 06:55 PM
Last Post: jagnew
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 17,204 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 24,414 05-01-2023, 11:52 AM
  My Came ZM3E gates won’t open golfnut75 1 10,766 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 14,926 24-06-2022, 08:58 AM
  Came Gates - power cut issues Paddy_SP 2 12,828 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  Came Double Swing Gates opens by itself for some centimeters risp73 0 10,230 19-06-2020, 06:19 PM
Last Post: risp73
  Came gates Ring8180 1 85,335 10-07-2019, 10:39 AM
