  • 33 Vote(s) - 3.06 Average
FAAC gates help - code change from previous owners
can solve the last part buy a new sim and you can top it up online no need to remove it. Or find out the old sim supplier and do that online. You can also reset the board back to factory settings it should tell you in the manual how to do this or download one. Just follow the instructions and it should be like a new install or you could use the old code to enter a new one if you got the manual
I had the same problem, and this is how i solved it. you will need to erase all the previous tel numbers from the system any way they will all still have access if it works the same as mine
Hope this helps
RE: FAAC gates help - code change from previous owners - by Ranch2 - 03-11-2022, 06:37 PM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,675 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,329 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,062 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,999 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,770 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,397 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,395 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,125 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,776 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
