  • 28 Vote(s) - 3.18 Average
Came Gates Error code E14
(22-10-2022, 04:16 PM)janker Wrote: Hi many thanks Ben
the connections all seem good ive tried removing both fuse on each motor put them back in and they worked twice then stopped again , ive narrowed it down to one motor if i remove fuse it must reset works for 30 seconds then stops each time i do it. any ideas what could be causing this  ? even without moving the gates it only stays on for 30 seconds then goes into fault.
Thank you for your response,
I would try removing everything from the system, so all that is connected into the control board is just the motors. This way we can be sure that it is nothing else on the system which is causing the fault, if you could let me know what happens from here I will be able to assist you further on the matter.
Came Gates Error code E14 - by janker - 19-10-2022, 12:48 PM
RE: Came Gates Error code E14 - by benbrooks - 21-10-2022, 11:50 AM
RE: Came Gates Error code E14 - by janker - 22-10-2022, 04:16 PM
RE: Came Gates Error code E14 - by benbrooks - 14-11-2022, 11:59 AM
  E8 error Code won't go away Singhsan 2 10,632 22-04-2025, 08:27 PM
Last Post: Mibbo
  Gates not closing Regor23 5 7,328 03-09-2024, 12:51 PM
Question Encoder Error!2 (ZM3EZ with ATS-P5) jagnew 0 6,263 29-03-2024, 06:55 PM
Last Post: jagnew
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 17,185 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 24,406 05-01-2023, 11:52 AM
  My Came ZM3E gates won’t open golfnut75 1 10,757 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 14,917 24-06-2022, 08:58 AM
  Came Gates - power cut issues Paddy_SP 2 12,815 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  Came Double Swing Gates opens by itself for some centimeters risp73 0 10,226 19-06-2020, 06:19 PM
Last Post: risp73
  Came gates Ring8180 1 85,328 10-07-2019, 10:39 AM
