  • 33 Vote(s) - 3.06 Average
FAAC gates help - code change from previous owners
(03-11-2022, 06:30 PM)Ranch2 Wrote:
(03-11-2022, 12:55 AM)trekkerglenn Wrote: Hi all,
Brand new here!
I've recently moved into a new property with already installed FAAC double gates, they work great BUT the other night I found the previous owner on my driveway (inside the gates) as they were coming to collect some old bits but rather than wait for me to arrive they used the gate code to allow entry
This has freaked me out a little and I now want to change the code on the gates for our new ownership, I a) have no clue how to do this and b) am worried it'll mess with the 'you can ring the gates from your mobile to open them' function too?
I've been told by the PO that there's a sim card inside the gates and this needs topping up for the mobile function to work, usually a £10 top up lasts 2-3 months?? again no idea if this can be brought into this decade as it seems a bit faffy to have to remove a sim and top it up every quarter?
Hopefully someone can offer a noob some help and advice
Glenn
Thank you for your enquiry,
Could you verify what dial to open system that you have on your FAAC System, if you were to find out where your GSM dial to open device is located (Usually in a IP rated box) we can hopefully open it up and identify which one you have and advise you accordingly.
RE: FAAC gates help - code change from previous owners - by benbrooks - 14-11-2022, 12:03 PM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,673 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,328 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,061 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,997 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,768 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,396 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,388 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,124 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,774 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
