  • 23 Vote(s) - 2.87 Average
BFT SubR not opening/closing sometimes
Hello,
I've had a pair of domestic gates for around 25 years which have been very reliable. Recently one leaf opens OK but on closing pauses midway ( and at that point you can move it manually for about a foot with no resistance) and if you leave it alone then it closes. Last week it opened OK but wouldn't close without me helping it by pushing then it started to not open as well. I can hear the motor running but the gate doesn't move. Other times it opens and closes normally.
I tried to undo the manual release triangular screw and while it turned a bit, the gate wouldn't release.
The oil hasn't been checked or changed for a while so I'm wondering if this is the solution or if there is air in the system that needs bled. I have the original manual but am reluctant to touch the bleed screws in case they break. A guy on a YouTube video says you can bleed the air via the manual release. I've also greased the top hinge so it isn't that.
It has been -5 degrees last week so perhaps the cold weather has affected it but it's not stuck to the gate stops or top hinge.
Any guidance/advice would be appreciated. Would like to try and avoid having to get the motor replaced if possible.
BFT SubR not opening/closing sometimes - by Jimmyboy4 - 18-12-2022, 09:49 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,478 14-06-2024, 12:12 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,219 04-01-2024, 10:21 AM
  BFT opening problem 8 55,647 08-08-2023, 02:14 PM
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 7,801 23-05-2023, 03:48 AM
Last Post: Bushpig
  Gates not fully closing stefen1978@hotmail.co.uk 2 7,362 10-10-2022, 10:07 AM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 20,221 19-08-2022, 09:30 AM
  LUX G BT 2B not closing properly since manual override swinnie 1 4,993 03-08-2022, 01:44 PM
  Slider closing then reopens 8" MWJONES 4 25,894 14-03-2022, 12:04 PM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 5,952 07-03-2022, 11:24 AM
  Phobos reversing after closing Sim75 0 3,950 21-05-2021, 07:04 AM
Last Post: Sim75
