  • 162 Vote(s) - 3.05 Average
Came gates stuck open.
(07-05-2018, 07:37 AM)Ring8180 Wrote: Hi I wondered if anyone can help?
I have a set of came swing gates which have been working perfectly until today.
They open fine on the fob or internal switch, but will not close automatically. When you press the fob to close them they seem to move 6 inches to close but then 're open. I have disabled the photo cell and have even changed the wiring around on the arm motors to see if they will close (which they do), but then obviously won't 're open, the pcb is a za3.
I appreciate any help
Thanks in advance Martin.
Hi Martin,
I seem to have the same problem, any chance you can share what was the issue?
Just to add to the detail, in my case i eliminated all sensors and even took the link to the leaf out. I also reversed the brown and black wires and i could see that the motor turns with every press of the key but when it supposed to turn the other direction it doesn't, in fact it rotates in the same direction as before, however this could be the residual charge of the capacitor, not sure if the last bit is valid, can't say i know enough about the electrical arrangement.
Tested the capacitors and perfectly fine: 15.8uF on a 16uF rated capacitor.
Regards.
Came gates stuck open. - by Ring8180 - 07-05-2018, 07:37 AM
RE: Came gates stuck open. - by Automatic-TC - 07-05-2018, 11:31 AM
RE: Came gates stuck open. - by Androidus - 30-01-2023, 12:08 AM
RE: Came gates stuck open. - by Ring8180 - 30-01-2023, 02:59 PM
RE: Came gates stuck open. - by Ring8180 - 30-01-2023, 03:14 PM
RE: Came gates stuck open. - by SamA - 03-02-2023, 12:12 PM
RE: Came gates stuck open. - by Androidus - 14-02-2023, 11:22 PM
RE: Came gates stuck open. - by SamA - 23-02-2023, 01:08 PM
  Gates not staying open JimM169 1 2,601 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,289 21-08-2024, 12:21 PM
Last Post: TheDock
  Nice MC824H gate stuck open Markp80 1 5,732 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 9,882 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 5,850 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 2,900 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 7,776 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 14,677 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 8,662 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 7,866 24-08-2023, 01:34 PM
