  • 162 Vote(s) - 3.05 Average
Came gates stuck open.
(30-01-2023, 03:14 PM)Ring8180 Wrote: Hi Androidus,
My problem was the wires into the Pcb had worn and were shorting.
I originally changed the capacitors and it made no difference.
It was only when I took the cover off the pcb i noticed the outer casing on two wires had worn
I hope you manage to sort it
Martin
P.s if you do manage to sort it, perhaps post on here
What the problem was, that way it may help someone else.
Came gates stuck open. - by Ring8180 - 07-05-2018, 07:37 AM
RE: Came gates stuck open. - by Automatic-TC - 07-05-2018, 11:31 AM
RE: Came gates stuck open. - by Androidus - 30-01-2023, 12:08 AM
RE: Came gates stuck open. - by Ring8180 - 30-01-2023, 02:59 PM
RE: Came gates stuck open. - by Ring8180 - 30-01-2023, 03:14 PM
RE: Came gates stuck open. - by SamA - 03-02-2023, 12:12 PM
RE: Came gates stuck open. - by Androidus - 14-02-2023, 11:22 PM
RE: Came gates stuck open. - by SamA - 23-02-2023, 01:08 PM
  Gates not staying open JimM169 1 2,601 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,294 21-08-2024, 12:21 PM
Last Post: TheDock
  Nice MC824H gate stuck open Markp80 1 5,735 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 9,889 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 5,858 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 2,900 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 7,785 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 14,683 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 8,669 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 7,870 24-08-2023, 01:34 PM
