  • 27 Vote(s) - 3.33 Average
Came FROG-A + ZA3 controller > gates wont close safety beam
(31-01-2023, 12:06 AM)Androidus Wrote: Hi,
 I have the same problem and exactly as described, there's actually a similar post - see below.
Any chance you identified the root cause?
Came gates stuck open
Regards.
RE: Came FROG-A + ZA3 controller > gates wont close safety beam - by SamA - 03-02-2023, 12:12 PM
  CAME ZF4 Controller Issue mduffy89 1 1,510 11-11-2025, 03:14 PM
  Came Frog nuphor 1 4,787 10-12-2024, 09:31 PM
Last Post: nuphor
  Gates not closing Regor23 5 7,338 03-09-2024, 12:51 PM
  CAME Frog AE-p24 kit Push Button Stuartl 2 7,240 20-10-2023, 08:57 PM
Last Post: Stuartl
  Frog A24E motor stopping SW1806 7 16,122 24-03-2023, 02:58 PM
  Gates out of sync frankjboyd 5 24,415 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 14,782 14-11-2022, 11:59 AM
  Came FROG A noisy fezster 1 7,688 30-09-2022, 03:16 PM
  My Came ZM3E gates won’t open golfnut75 1 10,766 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 14,928 24-06-2022, 08:58 AM
