  • 19 Vote(s) - 3.11 Average
Bernal Rallye C
Hi, after some help if possible.
My door mechanism was stuck and turned out to a simple fix that things has seized up.. WD40 applied and all worked well..
However, I attempted to put the cover back on, the door moved slightly (electronically, not by my moving it) and then stopped working altogether.
I know I slightly pulled a coupe of wires, which were the wall control and aerial.. They are secure now, but there is nothing working at all.
There is power, as the LED next to the manual override is on.. However, there is zero movement.
Had a garage door fitter around, but following some checks, he couldn't find the issue.. he did admit that electronics were not his strong point.
When I remove the circuit board, there is black on the transformer (connected to the motor which apparently brings the voltage down, i don't know). If this has gone, it's odd timing just after the thing was fixed... Could it be this or something completlely different..
Would appreciate any help out there.
Cheers
Bernal Rallye C - by pco0206 - 17-03-2023, 01:10 PM
RE: Bernal Rallye C - by SamA - 24-03-2023, 02:45 PM
