  • 20 Vote(s) - 2.8 Average
Came BX-74/78
(24-03-2023, 03:45 PM)cjd123x@gmail.com Wrote: Sam
Thanks so much for your help, I think I am getting there.
The motor will now respond to the key fob but only on one button, to OPEN.
Maybe I am being a bit thick but I cannot understand how I program in the other buttons.
The way I had it before; Button A - Open command, this would open the gate, the gate would then pause, fully opened, then close.
Button B was a PARK command, the gate would stop and stay ther until it got an OPEN command from button A.
Button C was a PARTIALLY OPEN command, the same as A but the gate only opened for pedestrian.
I have lost button B & C operations and I m struggling to set them up.
Your suggestion to link 1&2 has got things going again but I am puzzled as there was no link in there before?????
I am very grateful for your help.
Chris
Make sure Dipswitch 9 is on, this turns terminals 1 and 2 from a total stop (Normally closed contact) to a normally open (trigger). When you short with a bit of wire between 1 and 2 this will trigger the gate to open.
I believe on these remotes the functions are auto-assigned to each button. So if you do the same process as mentioned before but to all the other buttons it will assign them to their correct function.
If you are still struggling, please give CAME technical a call on table 0115 9210430
Came BX-74/78 - by cjd123x@gmail.com - 20-03-2023, 09:10 AM
RE: Came BX-74/78 - by SamA - 20-03-2023, 12:14 PM
RE: Came BX-74/78 - by cjd123x@gmail.com - 21-03-2023, 03:15 PM
RE: Came BX-74/78 - by cjd123x@gmail.com - 24-03-2023, 10:53 AM
RE: Came BX-74/78 - by cjd123x@gmail.com - 24-03-2023, 11:30 AM
RE: Came BX-74/78 - by SamA - 24-03-2023, 02:38 PM
RE: Came BX-74/78 - by cjd123x@gmail.com - 24-03-2023, 03:45 PM
RE: Came BX-74/78 - by SamA - 27-03-2023, 08:49 AM
