  • 17 Vote(s) - 2.94 Average
Replacement Above Ground Mechanism Advice
Great forum, thanks in advance for any help.
Currently have an above ground, single arm installation for a 10ft wooden 5 bar gate.  It has an electric locking mechanism added.  It is a domestic gate, probably opened/closed on average 4 times per day.
This is now no longer working, and a replacement is needed, the reason for replacement rather than fixing is for the following reasons:
  • A very rural setting and subject to inclement weather!  When windy the gate will not fully open or sometimes not even open at all
  • The arm mechanism has been damaged on a number of times when the gate half opens and the wind catches it
The time has come for a new gate plus a new opening to be installed.  The gate size will be the same in length.
  • The above issues will need to be sorted so I am presuming a more powerful motor is required (the previous one was specifically for the size but the weather issue was not taken into account I think)
  • Is it wise to order a heavier gate?
  • A locking mechanism is required again
  • Standard key fob access required unless suggestions otherwise
We have another gate with the same mechanism on which does suffer the same issue but far less frequently, I am loathed to change it due to cost, so would require the new gate mechanism and the second gate to be opened on keyfobs with 2 buttons, as we currently have.
Apologies if the correct terminology hasn't been used!
Replacement Above Ground Mechanism Advice - by Amadeus - 29-07-2023, 12:47 PM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,180 02-12-2024, 10:40 AM
Last Post: bing
  advice please shimself 0 1,909 11-06-2024, 09:09 AM
Last Post: shimself
  Replacement remote Chindley 1 6,028 06-12-2023, 03:00 PM
  Controller CL20S replacement Kaala1 6 13,289 15-03-2023, 09:23 AM
  Replacement Q60A board? ndyhzlwd 1 5,607 10-02-2023, 03:19 PM
  Sliding gate motor brand advice please! Trevreg98 0 9,015 12-01-2022, 08:40 AM
Last Post: Trevreg98
  Gate entry system advice please Happy Tv 2 18,442 19-01-2017, 04:11 PM
Last Post: Happy Tv
  Replacement Daitem D5131 Ningana 0 8,643 18-06-2016, 07:03 PM
Last Post: Ningana
  automated gate advice ljstevens 1 14,904 01-06-2010, 10:28 AM
  Gate automation failure/ replacement 3 28,022 15-04-2010, 02:01 PM
