  • 13 Vote(s) - 2.54 Average
Faac 452 pcb board
Thank you for your enquiry.
Could you confirm if it is the fuse below the transformer or at the top of the control panel in the middle of the board.
Also what accessories do you currently have in the control board, this sometimes can have back feed into the control board blowing the fuses and if it is the accessory fuse and you have safety sensors then this would explain the issue as it is probably taking out the sensors which is why the gate will not close due to a safety precaution, there is a way to test if we can get the motor moving by linking out the safety connections if you need to me show you how that is done please email me on technical@easygates.co.uk and I will send over some images.
Furthermore, are they underground motors that you have? Sometimes I have noticed once the box fills up with water they tend to do things such as blowing the fuses etc.
Faac 452 pcb board - by benner91 - 18-12-2023, 06:37 PM
RE: Faac 452 pcb board - by benbrooks - 12-01-2024, 10:16 AM
RE: Faac 452 pcb board - by benner91 - 09-02-2024, 06:13 PM
  Circuit board disabled CB124 - 7 flashes Tussun 6 21,309 15-08-2025, 01:57 PM
  FAAc xp20d wiring Neil Young 4 5,799 04-02-2025, 12:08 PM
Last Post: Neil Young
  FAAC gates out of sync TheDock 1 3,301 21-08-2024, 12:21 PM
Last Post: TheDock
  Fried control board nickfr 3 5,361 22-03-2024, 12:53 PM
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 3,631 14-02-2024, 12:21 PM
  Faac photocell stopped working Zeb Gulickx 2 7,903 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  TC fault code on Q60ar control board Skydive1710 3 9,760 20-11-2023, 03:12 PM
Last Post: NormanY
  FAAC E124 fault 05 allan@amtas.com.au 0 3,464 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 8,910 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 4,259 23-06-2023, 03:19 PM
Last Post: Alpin
