  • 16 Vote(s) - 3.06 Average
ZM3E underground loop problem
(12-01-2024, 10:07 AM)benbrooks Wrote: Hi,
Thank you for your enquiry,
Could you verify where the loop is wired into on your gate control panel, it sounds like it may be wired into 2 and 7 but in this case I would try terminals 2 and 3 which is an open only command.
Hi Ben,
 On looking at the board i see all wires going into 2 and 7. i will find the right loop wire and try number 3..
Thanks for your help
Mark.
ZM3E underground loop problem - by GhostUK - 05-01-2024, 03:13 PM
RE: ZM3E underground loop problem - by benbrooks - 12-01-2024, 10:07 AM
RE: ZM3E underground loop problem - by GhostUK - 14-01-2024, 12:10 PM
RE: ZM3E underground loop problem - by GhostUK - 18-03-2024, 04:37 PM
RE: ZM3E underground loop problem - by benbrooks - 20-03-2024, 10:46 AM
  Ground loop Came 009SMA arc497 0 3,725 14-05-2023, 12:02 PM
Last Post: arc497
  My Came ZM3E gates won’t open golfnut75 1 10,765 12-08-2022, 08:40 AM
  CAME ZM3E Mike2006 0 13,495 28-09-2020, 07:48 PM
Last Post: Mike2006
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 18,617 11-04-2018, 07:25 AM
  ZBK Master/Slave problem Steve Jefferson 1 30,753 09-11-2014, 06:43 PM
Last Post: Steve Jefferson
  Radio Problem Distance to Antennae whelan100 1 25,306 02-01-2014, 04:11 PM
