  • 31 Vote(s) - 2.87 Average
nice robus troubleshooting
(19-01-2024, 09:59 AM)Aiden Mitton Wrote: Hi,
Firstly, I would check the BlueBus LED on the control board as this is a diagnostic LED. If you get the fault to happen and check this LED this would be a good place to start as it will flash multiple times then pause, the amount of times it flashes depends on the fault which can be referred to in the manual.
If this is flashing once per second however, this is basically saying there is no issue. If that is the case, it may be worth disconnecting the photocells/accessories you have wired into the control board and try setting the gates up again, just so you can rule out whether it is the photocell causing the fault. Please note, when you remove/connect accessories from the STOP and BLUEBUS terminals, a BlueBus search would have to be done. To do this, press and hold STOP/SET and OPEN for around 3 seconds, L1 and L2 should start flashing quicker then switch to L3 and L4 flashing.
Many Thanks.
Thanks for the feedback.    Everything seems normal     It just never exits learning mode.  L3 and L4.
What status should the unit be in to open the gates using a remote control?
nice robus troubleshooting - by tarmongaidon - 26-06-2019, 10:47 PM
RE: nice robus troubleshooting - by tarmongaidon - 28-06-2019, 10:43 PM
RE: nice robus troubleshooting - by JoeF - 01-07-2019, 09:39 AM
RE: nice robus troubleshooting - by Aiden Mitton - 19-01-2024, 09:59 AM
RE: nice robus troubleshooting - by rhillhouse1976@hotmail.com - 24-01-2024, 05:14 PM
RE: nice robus troubleshooting - by Aiden Mitton - 30-01-2024, 10:41 AM
RE: nice robus troubleshooting - by hasanova - 30-01-2024, 05:19 PM
  Nice Robus closing after photo Nexur 1 7,245 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 9,579 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 7,914 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,598 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,231 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,361 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 4,940 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,094 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,407 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 7,815 10-12-2024, 10:31 AM
Last Post: dmrgate
