  • 25 Vote(s) - 2.6 Average
BFT Deimos BT A600 fault Error 10
(04-03-2024, 08:51 PM)GateOpe Wrote:
(25-05-2021, 08:28 PM)Airbus330/300 Wrote:
(24-05-2021, 10:12 AM)JoeF Wrote:
(23-05-2021, 03:28 PM)Airbus330/300 Wrote: I have an error 10 on BFT Deimos BT A 600. Manual states possible motor opening/closing
Contacts are seized.
Can any member advise where new relays for BFT Merak 600 can be purchased.
Relays are   WGR 24vdc.  RD - 124D - H1.      H2023J
Thanks in advance for any assistance,
hope you are well,
unfortunately you cannot purchase this part as a spare and therefore a new control panel will need to be purchased on this occasion
Regards Joe
Hi Joe,
Thank you for the prompt reply.
When testing resistance reading with a multimeter on the motor on BFT Deimos Ultra BT A600,
what should be the resistance reading be?
Many Thanks
Regards Gerry
Hi, i found your message here about BFT Deimos BT A 600 ERROR 10, Can you please tell me was was the fix? since i have exactly the same error now Sad
Error 10 is indicative of the following faults...
ER10
(BT motor)
Motor 1 relay running faulty test
- Motor 1 relay running control circuit failure
- Relay with stuck contacts
- Short circuit mosfet
- Check and remove the causes of possible high absorption of motor 1
- Reparation: replacement of shunt resistance, relay control circuit components, mosfet
It could be any of the following issues which may require replacing the faulty item.
RE: BFT Deimos BT A600 fault Error 10 - by JoeF - 24-05-2021, 10:12 AM
RE: BFT Deimos BT A600 fault Error 10 - by JoeF - 05-03-2024, 04:31 PM
  Question BFT Deimos A400 Makaroni 2 4,615 07-05-2025, 05:58 AM
Last Post: OnionBobo
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,098 15-10-2024, 10:37 AM
Last Post: Sootylfc
  bft deimos ultra bt600 error f1 pfloyd 4 7,988 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT deimos smoke from board stanli200188 1 4,070 05-03-2024, 04:17 PM
  thalia error code 3h 35/37/38 detritus 1 6,029 05-01-2023, 11:54 AM
  Lux/Thalia P ersl error Dava12 0 4,769 13-12-2021, 09:35 PM
Last Post: Dava12
  BFT Submotor fault Rockford 0 6,159 18-05-2020, 09:42 PM
Last Post: Rockford
  ERROR 11 TheoLouloudis 0 11,714 10-09-2019, 08:52 PM
Last Post: TheoLouloudis
  BFT Deimos Ultra remote problems shaggy 1 14,619 01-05-2019, 09:43 PM
Last Post: ok.dude
