  • 22 Vote(s) - 2.95 Average
Intermittent ‘Stop’ command - FAAC 741 Sliding Gate
(22-04-2024, 11:36 AM)benbrooks Wrote:
(21-04-2024, 05:57 PM)bwel Wrote: Hi,
I have a 741 that’s been running well for a few years. Recently I’ve found that intermittently it does not respond to an Open Input. Having checked and monitored the Gate Status Code Display, it seems to correlate to it thinking that a Stop input is present. Then at one point I found the display flickering between 2 (Stop) and 0 (Closed) when the gate was at rest Closed.  Yet my Stop input (Terminal 5) has a wire linking it to - (Ground) so should be a hard Normaly Closed input (not stop).
Has anybody experienced this type of situation or have any suggestions ?
Bob
Thank you for your enquiry.
This is definitely a strange fault considering you have the stop command shorted as it should be due to it being a safety input. Have you isolated the board and checked the back of the PCB for any sort of ingress and potentially a short?
I contacted FAAC Technical and they thought that perhaps the Magnetic Limit switch was not properly sensing the Close Magnet on the Toothed Track. I need to wait for it to fail again and check the FCC LED on the board.
Many thanks,
RE: Intermittent ‘Stop’ command - FAAC 741 Sliding Gate - by bwel - 22-04-2024, 01:01 PM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,674 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,329 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,062 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,999 13-03-2025, 10:05 AM
  FACC sliding gate not responding. Kipod 2 4,557 09-12-2024, 09:24 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,770 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,397 30-06-2024, 04:40 PM
Last Post: dennisoates
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,125 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,776 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
