  • 42 Vote(s) - 2.81 Average
#23
(10-05-2024, 03:47 PM)P100D Wrote:
(15-05-2023, 11:25 AM)Nemen3242 Wrote: Hello
Basically, I connected a hikvision relay DS-PM1-O1L-WE to the SBS contacts, I power the relay via STOP and PP as shown in the manual.  I do not understand why the opening works when I close the relay via the Hikvision AX Pro where the relay is enrolled, but it only close half a meter or something and than goes to full open again. I tried all settings in advanced settings for SBS (Open - Close - Open - Close etc) to no availability.
Thank you!
Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
RE: Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help - by Nemen3242 - 10-05-2024, 04:35 PM
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 102 10-12-2025, 09:42 AM
Last Post: mehsom
  Help me identify this mystery gate opener alpha 5 5,068 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 1,998 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 4,996 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,624 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,494 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,180 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,156 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,163 16-11-2024, 09:25 PM
Last Post: thronetm
  Robus Not Operating AlanWhite 3 16,761 11-09-2024, 05:00 AM
Last Post: Lee Zhang
