  • 42 Vote(s) - 2.81 Average
#28
(10-05-2024, 05:47 PM)Nemen3242 Wrote:
(10-05-2024, 05:38 PM)P100D Wrote:
(10-05-2024, 05:19 PM)Nemen3242 Wrote:
(10-05-2024, 05:02 PM)P100D Wrote:
(10-05-2024, 04:35 PM)Nemen3242 Wrote: Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
I didn't need to try because my other method worked (with access controller). But this should also work. Buy it from amazon, if it doesn't work, you just return it.
Thanks so I did a little experiment, and I think I solved out all this dilemma! I connected a wire between the SBS contacts, for the opening it worked fine, and also for the closing. Then what I did next was to keep the wire there for a several seconds. Boom, the closing has the same bad behavior. My Hikvision relay pulse default was 5s for pulse, hence the issues! I lowered that to 2s, all works fine! I'm 100% you had the same issue initially going from the Hikvision door station directly to the Nice. I know because I had to replace an older Nice600, not robus, and that door station relay worked fine!
Now we can put this to rest. No need for any access control. Regardless thanks, your replay made me think twice about certain things...
The logic seams right. My assumption was that it was the voltage. Perhaps it was the duration. When i changed the triggering device, probably the duration also changed as a side affect and made the problem go away.
It is the duration trust me. And yes for how it got fixed for you. I posted another thread on how to program the remote, any idea?
RE: Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help - by P100D - 10-05-2024, 05:54 PM
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 102 10-12-2025, 09:42 AM
Last Post: mehsom
  Help me identify this mystery gate opener alpha 5 5,068 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 1,998 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 4,996 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,624 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,494 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,180 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,156 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,163 16-11-2024, 09:25 PM
Last Post: thronetm
  Robus Not Operating AlanWhite 3 16,762 11-09-2024, 05:00 AM
Last Post: Lee Zhang
