  • 14 Vote(s) - 2.57 Average
Nice MC824H gate stuck open
(12-05-2024, 01:15 PM)Markp80 Wrote: Hi guys,
We have a Nice MC824H installed and recently it started to play up whereby the gates would stay open.
I ordered a new set of Nice EPMB photocells, fitted them and performed the blue bus learning procedure. This seemed to fix the gates and they started working again. However, I noticed the sensor on one side had no power and they do not stop the gates from closing when you get i  the way. I now tried to see why it waa getting no power to no avail and stopped the gates mid way. The gates are now stuck open again.
I have tried disconnecting the photocells and performing the rearning procedure without them but the gates remain open.
I found an old post that mentioned which lights should be on. Bluebus flashes green once per second, L3 and L4 are slowing flashing and Stop is permanently on red which I beleive is correct. However, neither ENC1 or ENC2 is lit.
Should they be and if not, what could be the problem? I opened up the junction box for the motor power and it is full of cobwebs. Wondering if it could be due to moisture or a fuse perhaps.
Mark
Hi Mark,
This sounds like it could possibly be an issue with an encoder, I would advise checking for any loose connections on your encoders. However, if there is water ingress present as you have said it could be caused by this, otherwise this could have just been a malfunction of the encoder. If the encoder is faulty the motor may need replacing however.
Jake.
Nice MC824H gate stuck open - by Markp80 - 12-05-2024, 01:15 PM
RE: Nice MC824H gate stuck open - by Jakedugmore - 13-05-2024, 02:32 PM
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 107 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,033 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,084 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,009 11-11-2025, 04:41 PM
  Gates not staying open JimM169 1 2,600 21-05-2025, 02:55 PM
  Peculiar automatic gate behavior Gatefreak 1 5,008 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,633 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,499 18-03-2025, 06:40 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,177 02-12-2024, 10:40 AM
