  • 15 Vote(s) - 3.2 Average
Gates not closing
(27-08-2024, 02:30 PM)Regor23 Wrote: Hello,
Grateful for some advice please.
I have a Came U1800 system with a ZA3  control board.
Gates will open using remote (new batteries & paired to system), but will not close when pressing remote.
Green led on control board is flashing.  Gates try to close briefly,  but then return open as if there is an obstruction.
1 set of sensors on outside of Gates are clean (tx was full of ants). No change after cleaning.
Bit confused as Dipswitch 5 is OFF.
Gates had been working fine until recently.
Many thanks for any guidance to sort problem.
Hi, I just replied to your email about my problem. Just to add to that, in case you were unaware, the picture I've attached shows you how to disable the sensors in order for the gate to close.
Bridge across 2 and C1
Use this info with care as obviously it will still close regardless of what is in the way.
Gates not closing - by Regor23 - 27-08-2024, 02:30 PM
RE: Gates not closing - by Ivorwindybottom - 31-08-2024, 07:09 PM
RE: Gates not closing - by Regor23 - 01-09-2024, 11:47 AM
RE: Gates not closing - by Ivorwindybottom - 02-09-2024, 03:40 PM
RE: Gates not closing - by Regor23 - 03-09-2024, 12:44 PM
RE: Gates not closing - by Ivorwindybottom - 03-09-2024, 12:51 PM
  ZL92 not opening but closing with videophone Mathi78 0 2,756 11-06-2024, 02:57 PM
Last Post: Mathi78
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 17,185 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 24,406 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 14,765 14-11-2022, 11:59 AM
  My Came ZM3E gates won’t open golfnut75 1 10,755 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 14,912 24-06-2022, 08:58 AM
  Came Gates - power cut issues Paddy_SP 2 12,815 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  Came Double Swing Gates opens by itself for some centimeters risp73 0 10,224 19-06-2020, 06:19 PM
Last Post: risp73
  Came gates Ring8180 1 85,328 10-07-2019, 10:39 AM
  Frog - ZA3: gates won't open BarryD 0 11,981 15-06-2016, 01:34 PM
Last Post: BarryD
