  • 25 Vote(s) - 2.76 Average
Help on Loss of Motor Powering Up
If the motor is humming, I would check the manual release to the gate/motor. You should not be able to move the gate manually.
It would be worth checking this fuse as this is for the control panel, but I do not think this is going to be the issue. To remove the fuse you would just use a small flathead and turn it in the groove anti clockwise.
I would also check the BLUEBUS LED when this fault occurs. This is because when a fault is present this LED will flash multiple time then pause indicating a fault in the manual.
I hope this helps,
Aiden.
RE: Help on Loss of Motor Powering Up - by Aiden Mitton - 30-10-2024, 10:30 AM
Last Post: gatekeeper
  BFT Gate Motor CDG 1 3,960 11-06-2024, 09:09 AM
  nice mca424 board or motor fault xjust 0 7,249 13-02-2021, 10:37 PM
Last Post: xjust
  NICE 1500A Gate motor and new intercom - fuse blown Phantome46 0 9,230 19-01-2020, 03:37 PM
Last Post: Phantome46
  How to connect two sets of photocell to wingo 5 swing motor Riyki 1 15,997 05-06-2018, 07:37 AM
