  • 415 Vote(s) - 2.91 Average
Proteco Advantage
HI Sean
No - "GO" is ever a brief message on the screen when the gate is activated either by key fob remote or by a switch (key switch, intercom, push button, loop detector). The "GO" is the control board saying "I'm being told to start".
If you are seeing a solid state "GO" and the gate does not respond, this is because the control board is receiving a constant "start" signal. This is caused by a closed circuit between terminals 1 & 8 (the manual start command input). It is like flicking on a light switch, it creates a closed circuit.
To resolve, first check that none of your key fobs are transmitting constantly (you would see a fixed LED light on the key fob). If this is fine, check any switching devices you have wired into terminals 1 & 8. For ease of back tracking, take out any connections you have in terminal 1 (this would clear the "GO", then re-introduce one at a time until you see "GO" stay on the screen,
Kind Regards
Proteco-UK
Technical Support 01202 744958
Proteco Advantage - by sarah - 31-07-2011, 09:00 PM
RE: Proteco Advantage - by Proteco_UK - 09-08-2011, 08:55 AM
RE: Proteco Advantage - by seanhoolan - 20-12-2011, 04:39 PM
RE: Proteco Advantage - by Proteco_UK - 21-12-2011, 10:12 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,410 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,361 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,154 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,458 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,876 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 5,583 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,818 12-01-2022, 08:13 PM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,218 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,068 09-10-2021, 07:56 PM
Last Post: Shane1
  Proteco Aster 3 ram fault soother 2 8,487 14-07-2021, 11:58 PM
Last Post: soother
