  • 18 Vote(s) - 3.39 Average
FAAC Eq45s , only Leaf A closing with remote
(01-03-2025, 05:06 PM)Cummil2 Wrote: Folks , I have a FAAC E145s driving my 2 leaf gate system ,
I replaced the board after power issue , programmed the remotes ,
Both leafs open if I use the key pad , and only leaf A with the remote ,
Have cleared the master and re done , still no luck,
Any help appreciated
Thank you for your message.
Could you please advise me on what remotes that you have as there are three different types with different programming methods. You have the LC/RC, SLH/SLH LR and the DS versions, I do not think this will fix the issue but may be worth a try in case the panel is getting its wires crossed when carrying out the programming method; you could try a fresh battery too.
It sounds like you are programming the remotes in a pedestrian mode which is why the remotes only open one leaf.
RE: FAAC Eq45s , only Leaf A closing with remote - by benbrooks - 13-03-2025, 10:06 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,651 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,323 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,987 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,766 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,388 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,377 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,117 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,768 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,526 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 12,073 21-11-2022, 09:54 AM
