  • 25 Vote(s) - 2.84 Average
Nice gates don’t close after the ambient temp is high
All gate equipment has problems, old nice boards suffer from frozen eproms. Gates ease of movement can change over time, so a relearn may be neccessary, unfortunately the board may be locked due to the corrupted eprom chip.
18 years is way past the designed life of Nice equipment, boards suffer from failed/scorched relays, blown capacitors, dry solder joints etc...
Sounds like it requires at the minimum a new board, if 230v motors go with a Beninca brainy 230v board, we've never had a problem with these as a replacement and they're cheaper than BFT. Don't touch the FAAC e145S it still has bugs and requires Simply connect pro to install correctly.
D
RE: Nice gates don’t close after the ambient temp is high - by old guy - 08-07-2025, 10:12 AM
  Nice Robus closing after photo Nexur 1 7,241 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 9,573 20-08-2025, 01:52 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,594 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,226 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,356 09-05-2025, 01:07 PM
  Mag-lock not activating after close benkay 4 9,161 13-03-2025, 04:19 PM
Last Post: ldkerlukeHome
  Looking for help with oldschool NICE gate motor gatekeeper 0 4,935 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,092 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,392 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 7,809 10-12-2024, 10:31 AM
Last Post: dmrgate
