  • 30 Vote(s) - 2.97 Average
CAME F7000 Gate Openers Issue
Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
I have F7000 openers.  I started to get an intermittent issue whereby the gates would open but then not close.  Only a few times per week.  Then it has got to the point where the gates don't respond at all.  From the beginning I noticed that the red LED was flashing constantly.
To try and fault-find, rightly or wrongly I stripped back all the connections from my sensors, external accessories etc to narrow down where the issue was coming from.  It seems that the red LED indicator on the board is constantly flashing which suggests that it receiving a signal from somewhere.  Therefore every time I pressed the button on the keyfob or keypad it couldn't receive the signal as it was 'engaged'.  However, with everything disconnected, it does the same - the LED is flashing.  Very occasionally I could press the fob and get them to open, but never will they close via the same method.
In my wisdom, I decided that maybe there was a board issue and maybe even a relay had gone or was getting stuck.  I bought a new board and swapped them over.  Same issue.  Even with everything disconnected.  It can't be the capacitor as I only replaced a few years ago and it is both gate openers that don't move.
It's worth noting that there has been creepy crawlies inside the box and so they may have shorted something or done some damage somewhere.
I'm now out of ideas and would appreciate any help and support you are able to offer as it is driving me mad!
Thanks in advance,
Jack
CAME F7000 Gate Openers Issue - by Jackolantern - 17-07-2025, 01:54 PM
RE: CAME F7000 Gate Openers Issue - by benbrooks - 11-09-2025, 10:04 AM
  CAME ZF4 Controller Issue mduffy89 1 1,502 11-11-2025, 03:14 PM
  CAME sliding gate drops codes after power outage Catch 1 7,291 02-03-2023, 03:18 PM
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 15,073 23-04-2020, 07:11 PM
Last Post: Luke Scott
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,164 02-05-2018, 06:18 PM
  Came sliding gate sticking on opening Jellybean 0 12,616 02-07-2016, 06:53 PM
Last Post: Jellybean
  Came gate opening adjustments TobagoGate 0 30,962 20-12-2012, 02:40 PM
Last Post: TobagoGate
