  • 24 Vote(s) - 2.79 Average
Help me identify this mystery gate opener
(06-07-2025, 04:12 PM)alpha Wrote: Hello everyone,
Not sure if this is where I should post this, but I'm trying to identify the exact model of some automatic swing gate operators at my school. I suspect they are BFT Lux hydraulic models, but I'm not 100% sure, especially given some visual differences from current models.
Here's what I know and observe:
  • Manufacturer: The flasher is BFT, and the beam sensor is Beninca.
  • Type: They are definitely hydraulic linear operators. I can hear a distinctive "shh" sound when they slow down, confirming they're hydraulic and not electromechanical.
  • Movement:
    • When an open command is given, the motors briefly run in the closing direction for about a second, then they start opening.
    • The left gate opens first, followed by the right gate after a 1.5-second delay.
    • The opening movement is not entirely smooth; it can be a bit jerky/bumpy.
  • Design:
    • They are quite long in design, consistent with robust swing gate operators.
    • As you can see in the photo, they have a distinctive three-section design. The main body, a central black cap/ring (which hides the manual release allen key port), and then the rear mounting section. This black cap acts as a clear visual separator between the two larger sections.
    • While they resemble BFT Lux models, the specific appearance of the "grey parts" and the distinct sectional design doesn't perfectly match all current Lux images I've found online, leading me to believe they might be an older generation. I'm wondering if they could be an older BFT Lux FC model specifically.
  • Manual Release Confirmation: I've personally seen maintenance staff access that central black cap to use an allen key. They did this when one of the gates was ajar (open a tad) to put it into manual release mode, allowing them to move it by hand and then "reset" the system. This confirms the presence of a manual release and likely a hydraulic lock.
Photo: The exact same “mystery model” I found at a tram depot on google maps, so here’s a image:
More Info:
- Flasher sequence: Slow flashing when opening, steady when open, fast flashing when closing.
- The gates seem to only open to about 80 degrees.
My Questions:
  1. Can anyone help me confirm the exact model or generation of these operators from the photo and description? Does the "three-section" design with the central black cap ring a bell for a particular Lux variant or older model?
  2. What’s the best way to get service for these gates? The one on the left is sometimes open slightly when I look at it (I don’t know the cause). Also, a magnetic lock is fitted, but the motor doesn’t push the gate far enough for it to automatically engage.
  3. Is the brief reverse movement at the start of the opening cycle a normal characteristic for BFT hydraulic operators like this?
Any insights or advice would be greatly appreciated!
Oh and here is a 3D render of what the gates look like. I made this for a school project:
From the look of the photos, and the motors having three sections to the body, they could be a type of BFT Kustos although without a closer image I wouldn't be able to make a judgement on an exact model.
If the motor is not quite reaching the maglock then I would recommend increasing the force of the motor and then putting it through a position learn.
 The reversing before the opening command could be down to the "ram" function on BFT operators it is typically activated when a maglock or electric lock is in use so the gates do not jam on the lock, however this can be turned off.
I hope this is of some help, if you have any questions please let me know.
RE: Help me identify this mystery gate opener - by Jakedugmore - 11-08-2025, 03:42 PM
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 113 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,046 03-12-2025, 04:18 PM
Last Post: StefanP
  Peculiar automatic gate behavior Gatefreak 1 5,011 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,637 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,500 18-03-2025, 06:40 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,184 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 4,168 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 3,997 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 4,633 28-08-2024, 05:13 AM
Last Post: drewdavis
