  • 5 Vote(s) - 3.2 Average
SEAV LRX-2186: gate opens a bit then stops
Hi all,
I’ve got a 2-leaf swing gate running on a SEAV LRX-2186 controller (230V motors). Since the colder weather started I’m seeing a strange problem and I’d really appreciate some pointers before I decide whether to replace the board.
Symptom
  • In the morning, when I send an OPEN command:
    • First leaf starts to open a little, then stops.
    • Sometimes it will try again, move a bit more, and stop again.
  • Around 09:00 and later in the day the problem is mostly gone and the gate behaves normally.
  • This started only recently; it used to work fine.
What I’ve tested so far
  1. Photocell / safety bypass
    • On CN2 I bridged terminals 8–9–10 (as per manual) so the photocell/safety input is disabled.
    • I removed power from the photocell completely.
    • I also disconnected power from an RTU5024 GSM unit I had connected, so right now it’s literally just:
      • LRS-2150 controller
      • Motors
      • Mains supply
    • Issue STILL happens in this “bare” configuration.
  2. Motor output voltage
    • When the gate starts moving normally I measure about 230 V AC on the motor output terminals.
    • When it does the “opens a bit then stops” thing and gets stuck mid-open, I measure only ~2–3 V AC on the motor output.
    • So it looks like the controller is cutting power to the motor completely (2–3 V looks like leakage, not real power).
  3. Reset and learning
    • I did a full reset / re-learning procedure from the manual.
    • During the learn cycle the controller drives the motors through the full travel and that process completes successfully.
    • After learning is done, when I send a normal OPEN command, the old problem comes back: gate starts, moves a little, then stops and I see ~2–3 V at the motor output.
  4. Photocell definitely not the cause
    • Because 8–9–10 are bridged, photocell has no power, and RTU is disconnected, I’m assuming the controller is not seeing a safety input any more.
    • The behaviour is exactly the same with or without the photocell connected.
What I suspect
Because:
  • Motors can clearly move the gate during learning,
  • Problem persists with all external stuff removed,
  • Voltage at the motor output is cut by the board when it stops,
…I’m leaning towards an internal controller issue, maybe:
  • Current-sense circuit or force-limit circuit thinking there is an overcurrent/obstacle and shutting the triac off,
  • Low-voltage PSU / electrolytic capacitors sagging under load (worse when cold),
  • Some weird parameter or EEPROM corruption where normal mode is applying a much stricter limit than the learn cycle.
Questions
  1. Does this failure pattern sound familiar on LRX-2186 boards?
  2. Are there known weak components on this board (e.g. PSU caps, shunt resistor, triacs) that typically cause:
    • learn OK,
    • normal run stops almost immediately?
  3. From your experience, is it worth asking an electronics tech to recap / repair the board, or is it usually more economical to just fit a replacement board (LRX-2186 New / similar)?
i attached a picture
Manual: https://www.manualslib.com/manual/157729...-2186.html
Thanks in advance for any help or hints!
SEAV LRX-2186: gate opens a bit then stops - by mehsom - 10-12-2025, 09:42 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 58,901 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,068 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 1,998 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 4,996 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,624 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,494 18-03-2025, 06:40 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,153 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 4,162 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 3,983 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 4,624 28-08-2024, 05:13 AM
Last Post: drewdavis
