  • 302 Vote(s) - 2.64 Average
BFT Electric subterrean gate control
I have a pair of 6ft wooden gates operated using the BFT underground kit fitted below the hinge points of the gates. The control programmer unit is mounted in a weathrproof enclosure and the gates are held closed with a mag-lock unit. The set up works fine with but two queries:-
i) When the gates remote is operated, the mag-lock doesn't release quickly enough to prevent the first motor from opening the first gate leaf, which causes the gate to 'pull' on the lock until it relaease. I have reveiwed the programming manual but cannot see how to introduce a delay for the first motor to allow time for the mag-lock to release.
I am concerened that over time, this constant 'pulling' on the lock will weaken the motor bearing. Unfortunately the people who installed the gates have gone bust and are no longer in business and BFT Tech Support said they would only discuss fix with an authorised installer!
Any ideas?
ii) The BFT key fitted was the 418Mhz system to prevent problems with the house alarm and garge remote control systems, which operate at 433Mhz. The BFT square key fobs I have, one is cracked and both keyring clasps have broken. I know this frequency equipment is now unattainable but I only need the cases, so I can swap the controller insides over.
Can you advise where I could get cases? I only actually need the single button variant, as the second channel on my gate remote is unused.
Any advice would really be apprecaited as I need to get this resolved before I can sell the house!
BFT Electric subterrean gate control - by Guest - 22-10-2009, 04:14 PM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,968 03-02-2025, 12:24 PM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,100 15-10-2024, 10:37 AM
Last Post: Sootylfc
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,660 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,512 14-06-2024, 12:12 PM
  Two BFT pairs of electric gates (one remote) Harry44 1 4,263 04-06-2024, 01:30 PM
  Gate radio receiver not working Zhymke 0 2,963 23-05-2024, 06:35 PM
Last Post: Zhymke
