  • 334 Vote(s) - 2.86 Average
Proteco Aster's Q60A shows a strange error
Manual says that between 2 and 8 you should have connected STOP button or just link if stop button is not in use. I would check if PCB track are fine. Maybe they are corroded and controller sees open circuit between terminals 2 and 8.
If connection is fine I would disconnect everything from the control panel, connect links where NC is required and see. If error will remain I would go with new control panel. They are not the most expensive ones ;-)
www.webseb.co.uk
RE: Proteco Aster's Q60A shows a strange error - by sebabastek - 25-01-2012, 10:40 AM
  Thalia P - BAR error devsolo 3 17,938 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,032 17-01-2025, 10:06 AM
  q60a stevea 1 2,498 23-08-2024, 12:14 PM
Last Post: stevea
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,409 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,358 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 5,612 10-02-2023, 03:19 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,143 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,455 12-07-2022, 11:48 AM
  Q80A Strange fault. Cannot work it out, if setting or fault? gray 0 3,384 25-06-2022, 08:14 AM
Last Post: gray
  Proteco Q60 - FH error then close after opening Needlerp 1 5,872 24-06-2022, 09:54 AM
