  • 474 Vote(s) - 2.95 Average
Dial2open , GSM gate opener.
Mark Wrote:To install this device i would use the bRight port and connect the power or red and black wire to the accessorie power on the left hand side for the CB24 then use the 2 x yellow normally open clean contacts to open and com on the cb24 it does not matter which way around for these wires.
Thanks Mark for the reply, to power the unit I was going to have its own supply as its instructions say
*IMPORTANT: The power source for the Dial2open unit MUST be capable of suppling
12 or 24V ac or dc @ 1 Amp minimum.
Be aware that most gate control panels CANNOT
supply this current.*
So I'd only really need to connect the 2 yellow wirea on the right port to the CB24.
Is there anyway to get a 12 volt input on the board so whenever the gates are opened I'll get the alarm txt off dial2open unit? (does that make sense?) flashing light or maglock could that be used to trigger it?
TIA
Dial2open , GSM gate opener. - by marknjo - 28-08-2008, 07:35 PM
RE: Dial2open , GSM gate opener. - by Mark - 29-08-2008, 01:47 PM
RE: Dial2open , GSM gate opener. - by marknjo - 29-08-2008, 06:30 PM
RE: Dial2open , GSM gate opener. - by marknjo - 11-09-2008, 09:36 PM
