  • 495 Vote(s) - 2.84 Average
not opening
sebabastek Wrote:Can be relay.
Try to swap motor outputs on the control panel and check if other motor (which now is fine) will be doing the same - what motors and controller you have got there?
I had similar situation with new install. Engineers called from site and told this is happening. I found lose wire in junction box (motors P7.5)
Try changing capacitors over to see if that narrows down the fault to a capacitor first of all as that seems quite likely.
i also agree with swapping the motors over on the control board, so motor one is connected to motor 2 and visa versa. if the other gate has the same problem then you will need a new control board as the relay is probably sticking. you could try hitting the relays with the plastic end of a screwdriver for a tempory fix.
if all of these fail, you may need a new motor.
not opening - by nskeates - 26-03-2010, 10:40 AM
RE: not opening - by nskeates - 30-03-2010, 07:38 AM
RE: not opening - by sebabastek - 30-03-2010, 07:03 PM
RE: not opening - by easygates - 31-03-2010, 05:03 PM
RE: not opening - by nskeates - 30-03-2010, 07:49 PM
RE: not opening - by sebabastek - 30-03-2010, 09:10 PM
RE: not opening - by nskeates - 31-03-2010, 07:59 AM
RE: not opening - by sebabastek - 31-03-2010, 07:53 PM
RE: not opening - by nskeates - 31-03-2010, 09:16 PM
RE: not opening - by sebabastek - 31-03-2010, 10:05 PM
RE: not opening - by nskeates - 01-04-2010, 06:48 AM
RE: not opening - by sebabastek - 01-04-2010, 07:35 AM
RE: not opening - by nskeates - 01-04-2010, 07:49 AM
RE: not opening - by sebabastek - 01-04-2010, 08:26 AM
RE: not opening - by nskeates - 01-04-2010, 08:33 AM
RE: not opening - by sebabastek - 01-04-2010, 08:43 AM
RE: not opening - by nskeates - 01-04-2010, 08:23 PM
RE: not opening - by sebabastek - 01-04-2010, 09:36 PM
RE: not opening - by nskeates - 02-04-2010, 08:07 AM
RE: not opening - by sebabastek - 02-04-2010, 09:10 AM
RE: not opening - by nskeates - 02-04-2010, 09:55 AM
RE: not opening - by sebabastek - 02-04-2010, 02:25 PM
RE: not opening - by nskeates - 02-04-2010, 08:10 PM
RE: not opening - by nskeates - 03-04-2010, 07:36 AM
RE: not opening - by sebabastek - 03-04-2010, 12:52 PM
RE: not opening - by nskeates - 06-04-2010, 09:56 PM
RE: not opening - by sebabastek - 06-04-2010, 10:01 PM
RE: not opening - by nskeates - 07-04-2010, 10:07 AM
RE: not opening - by Guest - 29-04-2010, 11:51 AM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,503 14-06-2024, 12:12 PM
  BFT opening problem 8 55,672 08-08-2023, 02:14 PM
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,471 09-01-2023, 10:29 AM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 20,249 19-08-2022, 09:30 AM
  Strange opening problem Baz1981 4 88,485 15-07-2019, 08:39 AM
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 63,329 23-04-2019, 10:11 AM
  BFT A 40 not opening tojo 0 7,578 06-12-2017, 11:29 PM
Last Post: tojo
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 21,342 23-08-2017, 02:39 PM
Last Post: Access-Control-Ltd
  Strange Gate Opening Issue scottc 5 36,198 09-06-2017, 03:41 PM
  BFT P7 Opening Time / Not Completing Stroke zootreeves 2 16,549 07-01-2016, 08:40 PM
Last Post: zootreeves
