  • 303 Vote(s) - 2.9 Average
Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
Gate automation failure/ replacement - by Guest - 11-04-2010, 07:10 PM
RE: Gate failure/ replacement - by easygates - 13-04-2010, 02:35 PM
RE: Gate failure/ replacement - by jgpp - 13-04-2010, 06:44 PM
RE: Gate failure/ replacement - by easygates - 15-04-2010, 02:01 PM
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 108 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,038 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,086 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,009 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,008 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,633 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,499 18-03-2025, 06:40 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,181 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 4,168 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 3,997 10-09-2024, 03:57 PM
