  • 326 Vote(s) - 2.7 Average
Proteco Advantage (Q60A) Error Code "03"
how controller reacts on open command from the terminals (1-8)?
I would disconnect everything from the panel (including motors) and leave only 19&20 connected which is 240V supply. Of course you have to leave links on safety devices and stop inputs. Then you have to give open command from the terminals 1-8 and see. If it works i would try give open command from remote. If it works i would connect one motor, then other motor then photocells and so on.
You have to check all step by step.
www.webseb.co.uk
Proteco Advantage (Q60A) Error Code "03" - by CLAUDIOTX - 18-03-2012, 11:17 AM
RE: Proteco Advantage (Q60A) Error Code "03" - by sebabastek - 18-03-2012, 01:56 PM
  Thalia P - BAR error devsolo 3 17,932 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,029 17-01-2025, 10:06 AM
  q60a stevea 1 2,495 23-08-2024, 12:14 PM
Last Post: stevea
  TC fault code on Q60ar control board Skydive1710 3 9,751 20-11-2023, 03:12 PM
Last Post: NormanY
Exclamation Proteco Q60A stopped working xCO 0 3,355 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 5,610 10-02-2023, 03:19 PM
  Q80A Fault Code kevcl15@yahoo.co.uk 1 5,578 03-02-2023, 12:00 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,141 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,452 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,871 24-06-2022, 09:54 AM
