  • 425 Vote(s) - 2.79 Average
PROTECO Q60S/R FAULT AND INSTALL
(05-05-2012, 11:07 AM)mohammed Wrote: hello
i bought Q60S/R motor and control board and installed it, but actually i didnt find any datasheet or limit switch with it although it is mentioned on internet that it needs a limit switch to be connected betweenpins 5, 6, and 8. so shall i buy one my self or what
and the problem now is thet the motor does not stop when the door is totally closed or open but it continues untill the preprogrammed time ends.
can any one give me any ideas to solve this problem
thank you too much.
Smile
there should be linit switches at start cycle and end cycle maybe magnet type but refer to installation instructions you have definately missed out there has to be one at both ends?allwys start in closed position.
is your gate slide or open type ?
(30-04-2012, 04:20 PM)jeffducati Wrote:
(30-04-2012, 08:43 AM)Proteco_UK Wrote: Hi
The Q60SR control board for swing gates showing "GO" error means that the control board is receiving a constant start signal caused by a closed circuit across terminals 1 & 8 (manual start command). This can be caused by incorrect wiring of push button switches, intercom connections and loop detectors. Anything that starts the gate other than the remote control key fobs will generate a "manual start command".
I would first remove all wiring from just terminal 1. This will remove the "GO" error and the gate may start. If it does, wait for the operation to complete, then you will see "- -" on the screen (stand by mode). Once this is seen, re-introduce one connection at a time back to terminal 1 until you see "GO" appear and stays there. As long as you know which piece of equipment is identified to terminal 1, you will be able to pin-point the unit causing the short.
If you require further info, please contact us as Gate Motors - support@gatemotors.co.uk
Kind Regards
Gate Motors technical Support
01202 717191
hi thanks it was a problem on that but manafactuers fault did not clear when i undone links so gone back for replacement.
thanks jeff
was on key switch switch faulty closed instead of open.
thanks
RE: PROTECO Q60S/R FAULT AND INSTALL - by jeffducati - 05-05-2012, 05:27 PM
RE: PROTECO Q60S/R FAULT AND INSTALL - by cciprian - 14-06-2012, 09:07 PM
  PROTECO Q60S BOARD DHOB123 0 8,684 02-08-2017, 10:52 PM
Last Post: DHOB123
  D5131GB FAULT Carlo 10 49,544 08-01-2017, 05:23 PM
Last Post: Access-Control-Ltd
  Q60S/R - Error code "P" DanyJee 0 8,856 04-06-2016, 10:42 AM
Last Post: DanyJee
