  • 313 Vote(s) - 2.73 Average
Proteco Q60A n2 error code
Thank you for your posting.
Indeed thank you for running a test i would have suggested (fooling board to think there is only one motor attached and running both independently from it) – however, if you swapped both motors round to begin with, would you still see N2? If this was the case, without a doubt I would feel there is an issue developed with terminals 16/17/18 and would look towards:
• The condition of the spade contacts on that terminal grouping
• The condition of the reverse side of the control board on the off chance something has run across the copper tracking
• The level of torque on that terminal grouping output (parameter F2)
Kind Regards
Gate Motors Technical Support
Proteco Q60A n2 error code - by Horace - 04-05-2012, 05:28 PM
RE: Proteco Q60A n2 error code - by Proteco_UK - 10-05-2012, 10:36 AM
RE: Proteco Q60A n2 error code - by Horace - 11-05-2012, 09:00 AM
RE: Proteco Q60A n2 error code - by Proteco_UK - 22-05-2012, 10:51 AM
  Thalia P - BAR error devsolo 3 17,935 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,031 17-01-2025, 10:06 AM
  q60a stevea 1 2,495 23-08-2024, 12:14 PM
Last Post: stevea
  TC fault code on Q60ar control board Skydive1710 3 9,754 20-11-2023, 03:12 PM
Last Post: NormanY
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,407 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,357 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 5,612 10-02-2023, 03:19 PM
  Q80A Fault Code kevcl15@yahoo.co.uk 1 5,579 03-02-2023, 12:00 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,142 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,453 12-07-2022, 11:48 AM
