  • 533 Vote(s) - 2.96 Average
Remote Control
(13-06-2012, 03:37 PM)Mick m Wrote:
(22-04-2009, 04:17 PM)easygates Wrote:
David Brisland Wrote:did you get this problem solved as i am having exactly the same problem
Hi, Make sure the radio card is connected correctly and all pins are connected. Try taking it out and re-inserting it just to make sure you have it plugged in correctly.
Have you tried another remote control? Or replaced the batteries in the one you are using?
Have you set up the photocells? you do this by turning the power off, placing a jumper over the terminals labelled "Save Fail Safe Photocells", then turning the power back on and removing the jumper after 15 seconds.
Check the "Stop" circuit is connected, there should be a link between "Stop" and "Com".
Hope this helps,
Hi i have done all of the above except i only have one remote as the other one was mislaid.I am also experiencing the same problem is there any test i can perform to determine if the remote is faulty
With just 1 x remote control it is hard to pinpoint if it is a remote control problem or radio board. I would get hold of another remote control and try that first if possible just incase it is a remote at fault
Remote Control - by Steve - 08-12-2008, 04:49 PM
RE: Remote Control - by Mark - 09-12-2008, 01:21 PM
RE: Remote Control - by Steve - 09-12-2008, 01:54 PM
RE: Remote Control - by Golfmadnut - 28-04-2016, 08:04 PM
  Control Unit Not Working mtuk100 0 41,821 10-10-2019, 03:14 PM
Last Post: mtuk100
  Which original remote control is suitable for board CB124 Evan 3 14,160 20-06-2019, 04:26 PM
Last Post: Devs
  Remote problem Nickhh 1 12,236 30-09-2014, 04:48 PM
  lyn300 control panel andy15 1 14,801 13-12-2011, 09:59 AM
Last Post: Mark
  Liftmaster 800 Remote KevinR 1 17,445 07-10-2011, 10:27 AM
  CB11 control box Intercom release button not working Moreteyne 0 10,517 14-09-2011, 03:14 PM
Last Post: Moreteyne
  Lost garage remote controller 1 19,380 25-01-2010, 06:12 PM
  Wiring Photocells on the CB11 control board Sparky 2 25,429 28-06-2009, 10:19 PM
Last Post: Sparky
