  • 274 Vote(s) - 2.91 Average
Proteco Q60S/R - Install probs??
We sell the Q60S/R with our sliding gate automation (Kit Roller 8 & 15). From reading your post it sounds like the photocells are tripping, but only when the gate is opening. This is what is called the Opening Cycle or Phase. More than often the photocells are wired in the Closing Cycle, this is where the gates open then close but the photocell beam is broken and the gates stop and reverse. It sounds like the photocells are wired in the Opening Cycle.
To check - on the control board the terminals are numbered 1 to 20. If the photocells are wired in the opening cycle I would expect to see a cable going to the photocell receiver out of terminal 4 and a link present between terminals 3 & 9. If this is the case, we can configure the photocells to the closing cycle by moving the cable from terminal 4 to terminal 3 and place link between terminal 4 & 9.
If you require further assistance please email us: support@gatemotors.co.uk
Kind Regards
Gate Motors Technical Support
Proteco Q60S/R - Install probs?? - by jadeella1 - 03-07-2012, 07:30 PM
RE: Proteco Q60S/R - Install probs?? - by Proteco_UK - 05-07-2012, 01:51 PM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,396 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,351 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,125 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,447 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,865 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 5,576 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,812 12-01-2022, 08:13 PM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,210 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,061 09-10-2021, 07:56 PM
Last Post: Shane1
  Proteco Aster 3 ram fault soother 2 8,477 14-07-2021, 11:58 PM
Last Post: soother
