  • 285 Vote(s) - 2.82 Average
Proteco Leader rams very slow
Thanks Martin,
I have indeed done exactly that, upped the power setting, extended the operation time by a couple of seconds and lubed the outside of the rams with liquid grease and all sorted.
David
(07-11-2012, 10:29 PM)scoobydoc Wrote: My experience is as the weather gets colder the rams get slower. I usually up the torque to get round this. The 2 really cold winters where there were sustained temps below zero i gave up.
I have however just placed a ram for these very reasons. Torque was upped but gate still slow or only opening 6 inches. New ram has solved problem but i understand if the capacitors are old they too could be contributory.
No maintence is required fir the rams. A little wd40 or liquid parffin helps with icing of the ram but the worm gear is self lubricating
Good luck
Martin[/php][/code]
[/quote]
Proteco Leader rams very slow - by drshemmming - 04-11-2012, 02:29 PM
RE: Proteco Leader rams very slow - by Mark - 05-11-2012, 12:34 PM
RE: Proteco Leader rams very slow - by scoobydoc - 07-11-2012, 10:29 PM
RE: Proteco Leader rams very slow - by drshemmming - 07-11-2012, 10:32 PM
RE: Proteco Leader rams very slow - by Proteco_UK - 15-11-2012, 11:29 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,396 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,351 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,124 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,447 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,865 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 5,576 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,811 12-01-2022, 08:13 PM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,209 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,060 09-10-2021, 07:56 PM
Last Post: Shane1
  Proteco Aster 3 ram fault soother 2 8,476 14-07-2021, 11:58 PM
Last Post: soother
