  • 197 Vote(s) - 2.54 Average
remote will open but not close garage door
Hi Dan,
If the LED's are flickering, I would expect that there may be a loose connection somewhere which might just need tightening. Failing that I would look at the Photocell covers and see if there is anything which has gotten in there. Spiders are a constant culprit with photocells as they like to build their homes in there! If all this has been checked and the problem persists, I would hazard a gues that they're knackered and need replacing!
Kindest regards
Dave
(01-08-2013, 07:32 AM)DJBenz Wrote: Hi Mark,
I have exactly the same problem with mine. The beam is aligned and I've made sure any obstructions are clear (the brackets being floor mounted means a build up of debris in that area). However, when I look at the green LED on top of the lense unit, it seems to flicker ever so slightly as if something is breaking the beam.
Is it likely the protector system is goosed and needs replacing?
Thanks,
Dan
remote will open but not close garage door - by Sharon OWest - 10-01-2012, 02:55 PM
RE: remote will open but not close garage door - by Blakey111 - 01-08-2013, 10:27 AM
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 27,548 19-01-2016, 07:10 PM
Last Post: DJBenz
  Door closes then opens again finescan 1 13,766 18-06-2015, 11:39 AM
  Can't reset remote for 5000UK david230757 3 20,319 16-01-2015, 11:27 AM
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 22,335 27-01-2011, 05:55 PM
Last Post: Mark
  poor remote range PeterH 4 23,618 27-05-2010, 03:22 PM
Last Post: Mark
  Where to buy Motorlift Garage Door Openers easygates 0 12,968 13-01-2010, 12:04 PM
  MotorLift Garage Door Openers 1 16,958 28-08-2009, 04:02 PM
