  • 310 Vote(s) - 2.86 Average
NR error code
Hello Dave,
Thanks for the response. I powered down, re engaged but still the problem is there. Normally the display shows in stand by mode '- -' when it receives signal from fob it turns to 'Go' then briefly 'NR' appears and comes back to '- -' [This was the original problem]
I solved this now. May be someone else will find this posting useful.
I disengaged both the motors and engaged them. Closed fully manually, re engaged again (note my gates engaged only half way through) powered up.
Works again as it should.
Thanks for all your help here in the forum and in Proteco.
Bara
NR error code - by Bara - 26-09-2013, 08:43 AM
RE: NR error code - by Blakey111 - 26-09-2013, 11:53 AM
RE: NR error code - by Bara - 26-09-2013, 04:43 PM
  Thalia P - BAR error devsolo 3 17,941 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,034 17-01-2025, 10:06 AM
  TC fault code on Q60ar control board Skydive1710 3 9,760 20-11-2023, 03:12 PM
Last Post: NormanY
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,413 26-09-2023, 05:32 AM
Last Post: max666
  Q80A Fault Code kevcl15@yahoo.co.uk 1 5,583 03-02-2023, 12:00 PM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,877 24-06-2022, 09:54 AM
  Deimos BT 400/600 error codes orange 0 5,958 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 11,179 02-09-2020, 07:06 PM
Last Post: Adam67
  Re: Error 30 tony.jay8 2 14,832 10-05-2018, 11:17 PM
Last Post: tony.jay8
  DAITEM WIRELESS INTERCOM how do I change entry code?? Help! Scarlett 3 28,608 04-05-2018, 07:43 AM
Last Post: Gagobaa
